Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › bosch shv55mo3gb/93 not pumping
- This topic has 8 replies, 3 voices, and was last updated 7 years, 9 months ago by
mrfixxer.
June 23, 2018 at 11:49 am #94125
mrfixxer
ParticipantHas the circulation pump gone ? it starts ok fills up but the water just dribbles out of the bottom sprayer nothing comes out of the top one.
June 23, 2018 at 12:44 pm #456513electrofix
ModeratorRe: bosch shv55mo3gb/93 not pumping
unless its blocked
June 23, 2018 at 1:10 pm #456514mrfixxer
ParticipantRe: bosch shv55mo3gb/93 not pumping
any easy way to check without pulling it out ? or could it be just the impeller not the actual motor.
June 23, 2018 at 3:00 pm #456515electrofix
could be the impellor
it is possible to see the impellor from the inside of the tub looking down the tube into the motor ( with a small mirror). you can see if it looks like the blades are contaminated. also the impellor had a nut moulded into it which means you can get a socket onto to it. you can then hold the fan stationary and the is an accessible screw driver slot on the end of the motor see if the impellor threads have stripped
you will have to remove the machine and take the side off
you can buy a new impellor for your machine as its an early unit
part no 419027
https://shop.ukwhitegoods.co.uk/419027- … l-kit-7964Dave
June 23, 2018 at 3:09 pm #456516Martin
It could also be a seized water diverter (aka duff instantaneous water heater unit)????
June 24, 2018 at 10:00 am #456517mrfixxer
cheers i will probably pull it out and inspect the pump and impellor.
i already replaced the drain pump 3 months agoJune 24, 2018 at 4:36 pm #456518mrfixxer
impellor was in two pieces looks like its just held on with plastic pegs
i am going to superglue the two pieces together temporarily to see if it works
June 25, 2018 at 12:09 am #456519mrfixxer
will impellor 165813 fit this machine also ?
June 25, 2018 at 7:05 am #456520electrofix
Gave you part number and link in previous post. Can’t say if another part number will fit unless Bosch lists it
