Bosch SL1501B dishwasher Salt light always on
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SL1501B dishwasher Salt light always on
Viewing 15 posts - 1 through 15 (of 17 total)
  • #83593
    RabMeercat
    Our dishwasher seems to have two faults.
    1. The salt light is now always on – we have always used 3in1 tablets and never out salt in
    Note: the salt dispenser is full of water
    2. The quick wash cycle is taking over an hour when it should be 30 minutes
    The filters and spray arms have been cleaned
    Hope you can help me please
    The E number is : SGS43T72UK/31
    #423189
    Re: Bosch SL1501B dishwasher Salt light always on
    the salt light will not go out unless you add salt. as you are using 3 in 1 tabs you may not need salt so ignor it. also you should not be using rinse aid as the tabs contain it
    is the dishwasher getting hot?
    RabMeercat
    If you mean does it wash the contents with hot water yes
    #423191
    RabMeercat
    WhAt about the time the cleaning cycles are taking
    #423192
    is the dishwasher plumbed into cold water or hot
    the most common cause of long programmes is heater failure. if yours is plumbed into hot you may think its heating when its not
    RabMeercat
    Thanks..its plumbed into cold?
    #423194
    RabMeercat
    The dishes come out clean so presumably the heater hasn’t failed?
    #423195
    RabMeercat
    And, when you open the door its steam coming out so definitely hot
    #423196
    does the owners manual state a time ?
    tried to look it up but i need full Enr to find a GB manual
    electrofix wrote:does the owners manual state a time ?
    No the manual doesn’t Dave (he stated the full ENR) 😀
    #423198
    RabMeercat
    Yep there is a paper insert with the cycle times and the one we use should be 30 mins.
    #423199
    and the manual states
    Programme data
    The programme data (duration, energy
    and water consumption) can be found in
    the summary of instructions and refers to
    standard conditions. Greater deviations
    may be caused by:
    different quantities of utensils
    inlet temperature of the water
    water pressure
    ambient temperature
    mains voltage tolerances
    and appliance-specific tolerances
    (e.g. temperature, water flow rate, etc.)
    ie its cold so water is colder (winter) so you have to heat it longer on both wash and rinse to get to temp.
    water pressure may be low or tap turned down or water valve letting in a bit slower than new.
    if there are more item in the dishwasher all these have to get to temp as well
    all there variances can add to the prog. if the eill valve is slow than it may not be long till you have to change it as unit times out if it takes too long to fill
    RabMeercat
    Thanks Dave, is an Eill Valve easy for me to replace ?
    #423201
    RabMeercat
    What is an Eill Valve and where can I buy one please?
    #423202
    He means ‘Fill Valve’ and no you don’t need to buy one.
