Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SL1501B dishwasher Salt light always on
- This topic has 16 replies, 3 voices, and was last updated 11 years, 3 months ago by
RabMeercat.
January 3, 2015 at 12:45 pm #83593
RabMeercat
ParticipantOur dishwasher seems to have two faults.
1. The salt light is now always on – we have always used 3in1 tablets and never out salt in
Note: the salt dispenser is full of water2. The quick wash cycle is taking over an hour when it should be 30 minutes
The filters and spray arms have been cleaned
Hope you can help me please
The E number is : SGS43T72UK/31
January 3, 2015 at 12:53 pm #423189electrofix
ModeratorRe: Bosch SL1501B dishwasher Salt light always on
the salt light will not go out unless you add salt. as you are using 3 in 1 tabs you may not need salt so ignor it. also you should not be using rinse aid as the tabs contain it
is the dishwasher getting hot?
January 3, 2015 at 12:56 pm #423190RabMeercat
ParticipantRe: Bosch SL1501B dishwasher Salt light always on
If you mean does it wash the contents with hot water yes
January 3, 2015 at 1:03 pm #423191RabMeercat
WhAt about the time the cleaning cycles are taking
January 3, 2015 at 1:10 pm #423192electrofix
is the dishwasher plumbed into cold water or hot
the most common cause of long programmes is heater failure. if yours is plumbed into hot you may think its heating when its notDave
January 3, 2015 at 1:13 pm #423193RabMeercat
Thanks..its plumbed into cold?
January 3, 2015 at 1:25 pm #423194RabMeercat
The dishes come out clean so presumably the heater hasn’t failed?
January 3, 2015 at 1:30 pm #423195RabMeercat
And, when you open the door its steam coming out so definitely hot
January 3, 2015 at 2:51 pm #423196electrofix
does the owners manual state a time ?
tried to look it up but i need full Enr to find a GB manual
January 3, 2015 at 3:19 pm #423197Martin
electrofix wrote:does the owners manual state a time ?
No the manual doesn’t Dave (he stated the full ENR) 😀January 3, 2015 at 4:31 pm #423198RabMeercat
Yep there is a paper insert with the cycle times and the one we use should be 30 mins.
January 3, 2015 at 4:59 pm #423199electrofix
and the manual states
Programme data
The programme data (duration, energy
and water consumption) can be found in
the summary of instructions and refers to
standard conditions. Greater deviations
may be caused by:
different quantities of utensils
inlet temperature of the water
water pressure
ambient temperature
mains voltage tolerances
and appliance-specific tolerances
(e.g. temperature, water flow rate, etc.)ie its cold so water is colder (winter) so you have to heat it longer on both wash and rinse to get to temp.
water pressure may be low or tap turned down or water valve letting in a bit slower than new.
if there are more item in the dishwasher all these have to get to temp as wellall there variances can add to the prog. if the eill valve is slow than it may not be long till you have to change it as unit times out if it takes too long to fill
January 3, 2015 at 6:49 pm #423200RabMeercat
Thanks Dave, is an Eill Valve easy for me to replace ?
January 3, 2015 at 6:56 pm #423201RabMeercat
What is an Eill Valve and where can I buy one please?
January 3, 2015 at 7:14 pm #423202Martin
He means ‘Fill Valve’ and no you don’t need to buy one.
