Bosch Slim D/W (SPS40C12GB/01) Burnt resistor on Module
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Slim D/W (SPS40C12GB/01) Burnt resistor on Module
  • #93964
    neon_3SP_glow
    Bosch Slim dish washer
    Model: SPS40C12GB/01
    9108 02422
    The Module has a burnt Resistor located just North of the big Black Capacitor.
    Any ideas How the Resistor is rated and where I could find a replacement? Willing to attempt a repair, its not definate that the module has corrupted itself.
    Thanks all, have a nice day now.
    #456049
    Re: Bosch Slim D/W (SPS40C12GB/01) Burnt resistor on Module
    chances are this is a fusible resistor where the power comes into the module. normally I expect about 50 ohms or so at about 3W (fusible)
    this resistor feeds the mains into a rectifier and the dc voltage at about 325v appears on the big capacitor. This voltage is then used by the 7 leg chip (TYN264) to lower the voltage for the module to 12v or what ever . If this resistor has blown I would suggest the TNY chip has also
    lots more examples of this failure in the sticky at the top of this forum
    neon_3SP_glow
    electrofix wrote:chances are this is a fusible resistor where the power comes into the module. normally I expect about 50 ohms or so at about 3W (fusible)
    Thanks for the reply Dave.
    Do you mean the ‘simple pcb repairs’ thread? I just scouted through it and didnt see anything similar? Maybe you mean another sticky?
    Cheers.
    #456051
    no it is simple pcb thread
    see page 4 entitled (Electrolux EWM1000 ) same fault as yours
