Bosch Slim Dishwasher
  • #33074
    pmb
    SPS2462gb/18
    Not filling, Inlet valve buzzing
    The valve seems to have anti flood device, Can it be reset.
    If i have to change valve, Is their an easy way to get at it.
    #237344
    Re: Bosch Slim Dishwasher
    pmb wrote:The valve seems to have anti flood device, Can it be reset..
    Disconnect the inlet hose coupling first, then reconnect it to vent the inlet valve. Inside the base there’s a clear plastic tube with a stopper attached to the end near the drain pump, remove the stopper and drain off any water in the hose. That is the water block system. The inlet/safety valve is accessible only via lowering the base unit IIRC? 🙁
    #237345
    pmb
    Thanks for info, It didnt work.
    valve buzzing but not letting water in, so i will have to get new valve
    #237346
    lerch
    General if the valve has a anti-flood built into it you can remove valve and give it a shake over the sink which will remove the water that gets stuck in anti flood bellows part and will generally start working again. If happens again replace then. Hope this helps
    #237347
    pmb
    It dosnt look easy to get out, so if we get it out we will just change it
    Next time we will try that first time, thanks
