Bosch SPS2462GB
Has worked an absolute treat until recently. Machine turned on, woke in morning has not progressed.
Tried again following evening, put on number 2. It drains first, fills, stops.
I thought, argh, must be stat or element.
Manually forwarded to wash cycle. Motor action fine. Went to bed.
Awoke, machine still washing, water was hot, eliminating the element being at fault.
I am assuming the issue is one of two things, stat or timer, timer being the stronger possibility, as stat kept water from over heating. I have tried the other programs, but the same issues.
Anyone advise, perhaps I have missed something
Additonally, I am in a very hard water area, not sure if that helps.
