Bosch Slimline dishwasher SRS56L08GB/16 not heating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Slimline dishwasher SRS56L08GB/16 not heating
  • #100823
    washingmachinewoman
    I rarely touch dishwashers because I don’t do integrated ones.
    I would appreciate some guidance on how to work on this model.
    Customer reports no heat and cycles taking forever. I have checked continuity and insulation of heater and that looks fine. Everything else is practically impossible to get to, so couldn’t check the thermostat. Is there a way to lift the tub? Any other possible cause of no heat?
    It drains ok.
    Many thanks!
    #482315
    RocketMan
    The first thing I would do is check to see if the this on Bosch Dishwasher recall list. Your model number is on there but dates are important, FD7901 to FD8504.
    If it’s within the date range get Bosch out. I’ve had a couple Bosch (and badged as Hotpoint) with various issues…mostly solved by Bosch replacing the control board.
    https://www.whitegoodsafety.com/product-recalls/3263
    #482316
    part of the mod is to add an external relay to control the heater as the original board had a tendancy to blow tracks by the heater relay
    so open the timer and look for track damage by the relay if no external relay is found
    washingmachinewoman
    Spot on advice RocketMan. It turns out to be one of the machines affected. Customer now trying to contact Bosch.
    I knew about the Whirlpool recall website, this one is potentially much better.
    Thanks Dave, if he doesn’t manage to get anywhere with Bosch, I will have a look at the board unless he decides to buy a new one.
    Lucie
