Have my trousers rolled up and just bailed out the kitchen after our dishwasher seemed to overflow!
Had a look at your really useful website and followed a few of the tips such as clearing out the filters etc.
Can’t get any further than an integral bowl at the base which has a vent with a feeder pipe returning to the rear!
Is their an easy way to clear out any blocks or am i at the mercy of the SERVICE ENGINEER! It would help if we had a manual but the dishwasher was here when we moved in a couple of months back!
Being a slimline makes it a real pain to get at anything to be honest, combine that witha solid base 😥
Can you hear the drain pump running when you select a drain function? and also could you please supply the full model number, usually found embossed around stainlees steel top of door inner (as you open door ajar look down onto door)
Yep, hence I need to know if drain pump can be heard. There are 16 models that match that description 😯
It could also be metering hose gunged causing excess water to flow out of breather on metering tank, but this would usually fill base and activate float.
