Bosch SM150M05GB/28
  • #70181
    DDDave
    This dishwasher overheats and stops with the 1 min left. I am thinking NTC but cant see one. Any advice please, is there a test procedure ? Thanks.
    #377305
    Re: Bosch SM150M05GB/28
    DDDave wrote:is there a test procedure ?
    Overheat (NTC) error would normally throw up an E11 error. The NTC’s are embedded within the heat pump itself, terminals 5,6 & 7. Resistance readings at 20C should be (approx) as follows: –
    Between terminals 5 & 6 = 10 K?
    Between terminals 6 & 7 = 10 K?
    Between terminals 5 & 7 = 20 K?
    HTH? 😀
    #377306
    DDDave
    Thanks Martin. As far as I know it doesnt come up with a fault code. Is there any test sequence for these machines ?
    #377307
    Bosch SM150M05GB/28
    DDDave wrote:Is there any test sequence for these machines ?
    Not to my knowledge unless you are employed by BSH and have one of their laptops you can plug in. Us on the other side of the fence have to make best the info that hangs on the grapevine. Sorry!
    #377308
    DDDave
    Thanks for your help Martin. I will be back to it tomorrow.
