Bosch SMI2032GB/14 (S6R28B) Built-In unit stops during cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMI2032GB/14 (S6R28B) Built-In unit stops during cycle
  • #59794
    IanMK13
    Bosch S6R28B built-in dishwasher (UK). Wouldn’t you know – first time it breaks down is on Christmas Day!
    Programmer stops after fill on prewash and stops again just before dispensing the detergent. I can manually move the knob forward to continue. The water fill is a lot quieter than I remember, too – I’ve got to get my ear right up to the door to hear it trickling in.
    Quite a basic dishwasher so I don’t think there are any diagnostics built-in. Are there any wiring diagrams or sequence details available online? What should I be looking for first?
    Thanks in advance for your help.
    Ian
    #339621
    CJAPeterborough
    Re: Bosch S6R28B Built-In unit stops during cycle
    Prob similar problem to this perhaps?
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=4770
    you can get schematics from the bosch support site btw
    https://www.bosch-eshop.com/eshop/bosch/gb/indexa.htm
    #339622
    IanMK13
    Thanks. I came across that thread this morning before posting my query but perhaps I didn’t give it due consideration. There was no mention of the washing sequence halting and – to my mind – that was my problem, although I realise now that I may have been to hasty and should go and check. I need to go back and read the post again, but more carefully this time.
    I’ve got guests here at the moment so not able to start taking the kitchen apart but I can confirm there’s no puddle under the unit. I’ve not been able to take the front panel off yet to see if there is any water in the overflow tray.
    I’ve had a quick look in the Bosch shop but couldn’t see any schematics immediately. I’ll go and have a good look around later.
    #339623
    CJAPeterborough
    you need to input the model number into the search box to top right of screen
    -it is etched into the door rim near the handle something like sms2002gb?
    #339624
    IanMK13
    Why they have a type number and an E-number I don’t know, but the E-number of my dishwasher is SMI2032GB/14. I can see only an installation instructions and an instruction manual in the Bosch eShop.
    I’ve now had a chance to remove my dishwasher and take a closer look. No water in the drip tray. I removed the sump hose and cleaned it. Surprised to find that it is rotting/melting at the sump end; the wall is quite thin and a replacement hose will be needed soon. The ‘triple measure’ water inlet appears to work OK but all the water appears to come via the water softener (bottom left-most inlet on metering tank assembly). Shouldn’t any come direct (I’m guessing from the bottom right-most inlet)? As I said earlier, I used to hear the ‘hiss’ off a mains pressure inlet when filling, but not now. Are there 2 solenoid valves in the Aqua-stop device? How can I check these?
    The initial problem I had noticed of the washing programme halting seems to be intermittent so opportunities to investigate are few and far between (and usually after the dishwasher has been re-installed !) but I did notice one instance where it stopped on pre-wash after the water had been added ( 3 measures) but before the pump had started. On other occasions it hasn’t stopped here. Does the programmer need any feedback from any sensor to continue at this point? Is there any way in which these 2 problems could be related? To my mind the programmer is a potential cause common to both but I don’t fancy paying £150+ on the off-chance.
    Any suggestions gratefully received.
    #339625
    CJAPeterborough
    search box top right should get you the schematics.
    https://www.bosch-eshop.com/eshop/bosch … I2032GB/14
    there is a box labelled search term on the top right
    #339626
    IanMK13
    Unless I’ve had too much Christmas Spirit recently, all I can see there are installation instructions and an instruction manual.
    #339627
    IanMK13
    I’m fairly sure that at least one of my problems is due to a slow fill (maybe the diswasher stopping mid-cycle is due to a timeout because of the fill taking too long?). I’ve tried resetting the AquaStop device but with no improvement. I can’t see where the water supply goes once it enters the dishwasher and it’s not at all clear to me how the water softener works. It appears that all the water enters via the bottom-left-most port on the metering tank assembly. Shouldn’t some enter via the bottom right-most port? If so, when? There is water in that line, so it has obviously got there at some point.
    I read somewhere else of the softener effectively ‘wearing out’. How would I know if this is the case? What should the colour of the resin be?
    Can anyone here enlighten me?
    Thanks,
    Ian
