Hi All
I was looking at this old machine earlier today for a complaint of sticking in cycle – turned out when I got there that it is taking about 10 – 15 minutes to fill.
As far as I can tell the resistances of the valves are OK, there is no muck in the hose filter and the water pressure for the machine should be OK, when I observed it filling with the side off it looked like it should start a syphon to empty the main tank in the water tank but it could only manage a dribble, as far as I could see there isn’t any blockage so I was wondering whether it is the aquastop valve not opening properly that is causing this – am I on the right path or is there likely to be something that I have missed – what do you think?
Also any service information that is available would be useful.
Thank you
Jem
