bosch smi50c05gb leak
  • #87911
    char14lew
    Could i have some pointers on how to get access to the back of the sump,I need to remove the pcb,it’s directly connected to the mains plug.The machine has a leak that looks like it’s coming from the rear of the sump,there’s drops of water on top of the circulating pump also.much appreciated.
    thanks
    #436398
    Re: bosch smi50c05gb leak
    Mains lead simply unplugs (like a kettle plug) from the back. The module can be lifted out once you remove the RH side panel.
    #436399
    char14lew
    thanks Martin,i see the lead unplugs but the board was not budging.It’s held in by a couple of plastic lugs which i released, but it wouldn’t pull free from the back where the lead plugs in.I’ll have another go when i go back.
