My Bosch dishwasher which is about 10 years old seems to have got stuck on a rinse cycle on whatever program is selected. After 5 mins it is finished.
Only advice I’m getting is replace the machine !
Any advice gratefully received.
1/ Broken wiring in the door, common now as these machines get older.
2/ The hose from the fill matrix to the sump is blocked/choked. Water backs up and operates the cut-off on the fill valve.
3/ Defective fill valve.
Power off if you plan to investigate this yourself.
