Re: Bosch SMI5506GB/05 D/W.
mike412 wrote:Anyone know what other heating problems this model suffers from?.
Mike,
Very often the valve at the bottom of the heat exchanger unit (thats the water matrix on the R/Hand side by the way) doesn’t shut off properly. (Often leaving a lot of water in the tub at the end of the cycle by the way). Now if the heat exchanger tank doesn’t fill correctly because of the dodgy valve, then insufficient water flows through the heater and the heater pressure microswitch doesn’t kick in 😉
Worth a look whilst you’ve got it out, easy machine to work on when you have 🙂
