Bosch SMS 4452 dishwasher leaving from overflow
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS 4452 dishwasher leaving from overflow
  • #20039
    hopalong
    Hi I’ve got a bosch 4452 dishwasher.
    on the left hand side of the washer there is an intricate plastic setup which controls the filling. in the bottom right hand corner to the right of the microswitch and float assembly is a 3/8″ overflow hole or air vent which on the third cycle of filling overflows for about 10 seconds until the water level drops and the washer starts to wash. Any idea whats causing this.
    There appears to be no blockages I can see and the water appears to fill properly. Any help appreciated. 😕
    #185543
    superfix
    Re: Bosch SMS 4452 dishwasher leaving from overflow
    Suspect that your sump hose is partially blocked.
    #185544
    hopalong
    Cheers, top marks!!
    Cleaned out the pipe, only found two tiny lumps, but they were obviously enough. Works perfectly now.
    Many thanks for you help. much appreciated 😀
    #185545
    superfix
    No problem 8)
