Bosch SMS 5342 Dishwasher
I sprung a leak in the exhaust hose. The first offering from the local plumbers merchant – a generic drain pipe , anyone want it 🙂
(I did tell them it was a Bosch and took the old one along) wasn’t a water-tight seal on the outlet and i got a bit of water spraying out from where it fits onto the transparent bit at the side . So I’ve got the Bosch part fitted but now when i turn it on it doesn’t fill with water .
the only thing taht has happened AFAIK is that when I started getting the water coming out towards the end of the cycle , I reset the machine via the CP on the front (the normal and quick cycle keys together) .
and now i dont get any water flowing into it
So the solenoid isn’t opening ?
Any thoughts why ?
and where is the solenoid ?- it all looks very very cramped in there !
ive tried resetting the machine half way through a (now dry) cycle but that hasnt solved it.
