Re: BOSCH SMS 65 Spray arms not turning. Dishes not clean.
The m/c no is SMS6502GB-07.
Lack of water? It seems to fill up OK and the dishes appear wet and it does wash them a bit. What puzzles me is the spray arms no longer turn. They are free and unblocked but something is wrong.
What tests or info do you need?
Should I check the pump impeller is turning as the little video on the BOSCH web site?
Lack of water to the spray arms is what Martin refered to Chris 😉
They rely on water pressure to make them rotate so they are either blocked (ruled out by the sound of it) or there is insufficient water pressure to them which could either be a blockage or the main circulation motor is failing.
Power off when checking please :zap: or if you’re uncertain please ask an engineer to attend, Repairs@ should provide one 🙂
