Hi – I have a Bosch SMS 6702 GB/09 dishwasher.
Water is collection in the tray and tripping the float system.
The source of the water is under the right hand side (as you stand looking at the front of the machine) panel.
There is a large water tank and a smaller flat plastic tube the runs up the rear elevation of the side panel and connects at the main metal drum there.
At this union the leak is occuring and then during the wash/rinse cycle water is expelled from this union running down the flattened plastic pipe and into the tray.
Question:
Can I remove/repair this union with standard parts and are schematics available on-line somewhere to show me the parts numbers I need to buy?
Hope to hear from you soon.
This problem has recurred after engineer was called out in September and ‘fixed’ the original fault.
