Bosch SMS 69T18AU check water supply error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS 69T18AU check water supply error
  • #89015
    orinoco
    Brand new dishwasher won’t work and keeps giving “check water supply error” after a few minutes of starting.
    I have exhausted all avenues I can think of:
    Bosch service can’t help;
    Water supply authority can’t help;
    Plumber can’t do any more (already spent $500 on plumber);
    Service technician can’t help;
    Local retailer can’t help me find a model that will work.
    I have a low flow apparently… of only 7.5 litres per minute at the water inlet connection point.
    Is there any way around this on the Bosch?
    Is there a make and model that isn’t so sensitive to low water flow?
    Can’t believe I am (it seems) the only person in Melbourne Australia with this issue…
    #440061
    Re: Bosch SMS 69T18AU check water supply error
    its a problem with a lot of modern appliances where the water pressure is low
    in the area where you live do other people have low water pressure problems ?
    you could add a pump to raise the pressure.
    orinoco
    Hi Dave,
    Yes the neighbours also have low pressure.
    I am coming around to the idea of the pump to increase the pressure… I would prefer to buy another dishwasher if I knew it would work rather than introduce a pump (and hence another potential point of failure).
    If I do go down the pump road then I have to weigh the pros and cons, I don’t have a lot of room for a pump.
    Thank you for the reply,
    Justin
    #440063
    have you asked you neighbours what units they have ?
    might give you a clue as to which ones may work
    orinoco
    Yep – they have a bosch! But not as old as mine.
    Will ask the other neighbours on the weekend…
    Spoke before to an experienced technician and he has come across the problem a few times… he recommends a booster pump to fix the problem as well.
    I will have to get serious about researching a pump.
