Bosch SMS 903 Dishwasher not using salt
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS 903 Dishwasher not using salt
  • #9725
    pip268
    I haven’t had to replace the salt in my dishwasher for ages. I keep checking the container but the same amount of salt is still in there.
    When I open the salt container cap the water comes out.
    I took the side panel off and set it to do a quick wash.
    The 2 pipes going to the salt regulator never get any fluid inthem.
    Thinking the salt regulator was blocked I disconnected the pies and did another wash. Stll no joy.The water just doesn’t get to these tubes.
    I can see plently of water swishing around in the salt container and can see activity in the softener compartment.
    Any help would be appreciated.
    #135521
    Re: Bosch SMS 903 Dishwasher not using salt
    Regret SMS903 is not a valid model number – please recheck.
    Initial thought would be some sort of solenoid failure on the fill matrix.
    The operating booklet says if I open the door I should see an FD number and a machine no. but I can’t see anything.
    #135523
    Dave_Conway
    The label has fallen off then I expect 🙂
    It should also be on the rear of the appliance 😉
    #135524
    pip268
    There’s absolutley no ID anywhere on the thing.
    Anyway following Penguin’s hint I found that the solenoid on the bottom of the salt/softener container is open circuit.
    I’ve now got to try and get a replacement.
    #135525
    pip268 wrote:I’ve now got to try and get a replacement.
    If the hose that passes across the salt valve is blue in colour, then you need a 051835 Salt Valve. 😉 (‘Cos I suspect the machine is a SMS6032 series)
    (Take a digital photo and send it me if you like of it in situ?? 💡 )
    And if you speak to Dave_Conway nicely via his email address (below), he most likely can get one for you!
    spares@ukwhitegoods.co.uk
    #135526
    pip268
    Thanks Martin. Much appreciated.
    Yes the hose is blue. I will be emailing Dave.
    Some outfit said I could only buy the whole container assembly and needed all the exact model nos. which of course I don’t have.
    Having done a bit of research on the net I have determined that it is a SMS6032 series.
    Thanks again.
