Bosch SMS24AW01G/48 Dishwasher, Obtain error codes pump not emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS24AW01G/48 Dishwasher, Obtain error codes pump not emptying
  • #98907
    Johnkennard
    Hi, this is a basic dishwasher with no Hrs panel to display error codes, is there a way to extract blink codes to see what the errors are? Also is there a way to clear down codes? The machine will fill and wash but will not empty, the pump makes 3 pathetic attempts to pump out but then fails until you recycle off and on. The same happens if I raise the flood float the pump, pumps for 2 seconds three consecutive times with 5 second gaps between and ceases until cycled off-on.
    I have checked all the outlet pipes and the accumulator on the side of machine for blockages but all is clear. The pump is directly wired to the main control unit and wonder if this is possibly where the fault lies, but without codes cant make a decision. Yes I have tried a new genuine Bosch pump but the fault is still exactly the same. The machine is only 3 years old, Can someone help please.
    #474258
    does sound like a board fault
    Johnkennard
    The trouble is that sort of advice is helpful but not precise, do you know how to extract the fault codes on this particular machine? I thought all SMS model machines have codes?
    #474260
    the pump is a 3 phase motor. the mains supply is single phase. the board has to convert the single phase supply to a variable frequency 3 phase supply. in the old days the pump was either on or off but now its a lot more complicated. On top of that the board measures the current going to the pump to determine if the machine is empty. They call it virtual sensors
    to add to the problems bosch will not release ant tech info unless you are a bosch agent, and i am not, and they have strict instructions not to release it
    there are a few manuals for american machines on manualslib but thats it
    so it sounds like the board is having problem initiating the 3 phase supply to the pump. i cannot think of any external component or fault that could cause this
    Johnkennard
    Thank you Dave, it does seem strange that there is so little on this problem up here on the net about codes for this machine. Having spent 45 years in the motor trade I do know OBD codes have to be published by law but manufacturers codes which are far more relevant they hold tight to their chest unless you part with a lot of money. I have a list of codes for this machine but does any one know whether you need a diagnostic device to extract them or is there a button sequence to use and read blink codes??? I may have to look into those American manuals.
    Once I realised the new pump had the same symptoms I left it in place after a rinse cycle, Then connected the old pump electrical plug with the pump sitting on the ground and cycled off-on the pump pumped continuously for approx. 40-50 seconds as if it were emptying the machine it had no load and made me wonder about the exit pipes being blocked or even the accumulator. I have had all of them out and cleaned them. I have had the pump out and put a tube up the exit tube, there is a one way flap valve in the base unit I assume to stop dirty water running back after pumping, a volume of water did flow back when pushed past but everything is clear as a whistle. I would guess an electrical overload mechanism is built into the control board in case a piece of glass or debris get’s caught in the pump and this may be the fault that it has become over sensitive???
    John
    #474262
    Johnkennard
    FIXED A bit embarrassing this one, the new drain pump fixed the problem but would not run correctly. The reason was my son stripped the machine and I got involved when the new pump didn’t work. Having got the machine stripped he had removed and cleaned the plastic accumulator on the side of the machine. We experimented to see if the pump would work with a half stripped machine and got nothing but 3 pulses. The reason being a short breather pipe had not been refitted to the accumulator and it would not allow a syphon effect to take place on the outlet pipe so the pump would do nothing but pulse 3 times. I am afraid it took a local tradesman to spot the problem and rebuilt the machine and all works fine. Although a new pump was fitted I tinkered with the old pump and found a dry solder joint on the small PCB supplying the motor windings and re-soldered all 3 joints. I know it works because we retried it before the breather pipe was refitted and it also pulsed 3 times like the new pump and ran properly external to the machine.
    Thank you for everybody’s help and I hope you find this information helpful. I know it was family but always strip a machine on your own!!!
