Bosch SMS25E100G Dishwasher Error Code: E19
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMS25E100G Dishwasher Error Code: E19
  • #101219
    jontymox
    Good afternoon all,
    Wondering if anyone can shed some light on the above Bosch dishwasher error code?
    I’ve just arranged to visit a customer on Wednesday, who said the only symptoms were the above code, and to contact Bosch to arrange an engineer visit.
    The Bosch website states that the error means that there is a problem with the heat exchanger.
    UKW dishwasher error codes confirms an engineer visit is required, so it would appear I need to be concentrating on the heat pump…
    Just wondering if anyone can confirm this, prior to my visit?
    Many thanks,
    jonty
    A
    #483881
    ray.t
    https://www.bosch-home.co.uk/store/11033896
    Had one the other day, same error code
    #483882
    jontymox
    Thanks ray.t,
    Appears to be a suspect heat exchanger outlet valve, and wonder if it can be conclusively tested?
    jonty
    #483883
    like any solenoid valve it can be checked for continuity
    as far as the timer is concerned its open circuit either by fault coil or faulty wiring
    matrixresonator
    IIRC the heat exchange valve should read between 7-9 ohms.
    #483885
    matrixresonator wrote:IIRC the heat exchange valve should read between 7-9 ohms.
    are you sure about that. the valve you linked to is 325v DC and at 9 ohms that gives a current of 36A
    matrixresonator
    There was a tech note on ASWO’s EURAS system that gave the values, not at the right pc now to get on and check.
    #483887
    think he missed K out so it will be 7 to 9 K ohms I think
    matrixresonator
    That sounds more likely, sorry just got home and not eaten yet!
    #483889
    clockworkone
    Definitely a van stock item. A handy job though even if a little bit of a snug fit.
