This fault has been intermittent for a week or so but I have alwys been able to clear it by removing and refitting the plate below the lower spray arm.
However, now this does not work.
I’m told this part is the culprit, but not for this particular dishwasher model. https://shop.ukwhitegoods.co.uk/00611316-heat-exchanger-valve
Could anyone please offer advice / a solution please?
Thanks in advance
Andrew
When does the code come up. As soon as the machine is turned on, when you press start and close the door or just after the wash part of the program has started
The code comes up a few seconds after pushing start. The machine clicks as though starting to fill then the code appears no matter which wash program is selected’
