Bosch SMS3042GB/03 heater element search
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS3042GB/03 heater element search
  • #27661
    sebrof
    hi
    i’ve got a venerable Bosch dishwasher that has run perfectly for over 15 years! It’s now shorting out my house’s power and I guess it’s the heating element that’s gone. The problem is that I can’t find anywhere that does spares for this old girl. Anyone know a good site that I can go to?
    Thanks!
    #215091
    Re: Bosch s5nz27b heater element search
    15 year old Bosch should have model info on the casing surround at approximately the one o’clock position.
    gegsy
    You could always test the heater to confirm you know 😀
    The older Bosch used to suffer from damage to the loom at the point where the door and loom pivotted, some bare wires even burnt a hole through the stainless 😯
    Has to be worth a check there if heater tests ok.
    Un plug appliance if you are to investigate :plug:
    sebrof
    There is a label inside where the door closes at top right.
    E-NR SMS3042GB/03 PD7101013698 IS IN A BOX
    THEN UNDERNEATH IS SMS 0730 102986
    THEN ON THE RIGHT typ S5N27B
    #215094
    gegsy
    If it turns out to be the heater it is p/no 282746 possibly available for spares@ukwhitegoods.co.uk but due to age it may be obsolete 😕
    sebrof
    Re: Bosch SMS3042GB/03 heater element search
    Thanks for all the help!
    #215096
    Kentish
    Part shouldn’t be obselete, however if you can’t get it through Appliance Care or the Bosch web site http://www.bshappliancecare.com/Bosch/boschspares.html
    (then click on QuickFinder to open the spares section and type in your model number), a decent spares supplier should be able to give you the Hotpoint equivalent (as they used the Bosch dishwashers at that time) which I have always found to be cheaper than the Bosch labelled item (identical apart from part number label)
    #215097
    Not to mention our very own Dave on spares@ukwhitegoods.co.uk ……….
    gegsy
    I did mention but………..
    #215099
    I know you did……….
    :p45:
