Bosch sms40a02gb/01 not filling Check water light comes on but no error codes, customer has been tilting washer to empty base then using machine as normal,now it wont work,,had a peak at the solenoid valve on the water inlet it looked a little charred on the connector. solenoid checks out ok but im getting 240v on each side of the solenoid, would this be a possible neutral fault on the main board? I am presuming hes tilted it got the solenoid connector wet then turned it on resulting in board damage?? Thanks for looking any help appreciated.
Darren
