Bosch SMS40A06GB Check Water error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS40A06GB Check Water error
  • #98164
    ianmcairns
    This error has come on at the start of a new cycle – the machine sits there clicking and won’t fill. I have checked the water flow, the in-line filter, the waste hose and the impeller in the drain sump – all good. The drain sump had some dirty water in it which I hadn’t noticed before and which I’ve bailed out.
    What is the most likely cause or the next place to check? It could be the inlet solenoid valve but at £35 a throw it’s an expensive guess. On the other hand, the dirty water could indicate a pump-out fault?
    Any help much appreciated.
    #471140
    first thing any programme does is pump. if you put a jug of clean water in. start a programme it should pump that out first. Does it ?
    ianmcairns
    I have put some water in the bottom but it does not pump. It just sits there clicking and after about 10 secs comes up with the check water error. In fact the on/off power button is inactive and the machine doesn’t even get as far as programme select.
    #471142
    and you say you have checked the pump impellor and its free to turn and not jammed by glass ect
    ianmcairns
    Yes the sump area is clear and I can turn the impeller with my finger.
    #471144
    in that case it sounds like an electronic fault
    there are 2 boards ( looked one up at random as the model no is not complete)
    main board £121
    control panel £52
    as far as programme select is concerned it may be in the middle of an operation and will return to it when its turned on
    ianmcairns
    Thanks Dave. It had finished its previous programme fine so it’s just not starting up. I guess there are no diagnostics to say which board it could be?
    #471146
    my guess would be the lower board but no there is little or no tech help with bosch
    i take it you have had no signs of mice as i have had cables eaten over the years causing odd fault along with slugs crawling onto boards
    you could take the board out and look to see if you could see anything
    ianmcairns
    Is it easy to get at? I’ve no idea where it is.
    #471148
    rear right hand side where the cable goes in
    ianmcairns
    OK many thanks Dave
    #471150
    adv
    check water light on. is usually the flow meter impellar jug if has one
    #471151
    adv wrote:check water light on. is usually the flow meter impellar jug if has one
    agree m8 but for some reason this one is not doing the initial pump out according to the posts and as far as i know that should happen at the start of every programme
