Bosch SMS40A08GB stops and starts during cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS40A08GB stops and starts during cycle
  • #97963
    jb72
    Our dishwasher seems to have 2 (connected?) problems –
    – it will stop during the cycle – the display flashes suggesting the door is open – the door isn’t open but a gentle push restarts it
    – it again will stop completely – lights go out – opening / closing the door does nothing – left for a while the power returns and it continues
    Having spent some time searching the second problem is maybe a power problem on the main PCB?
    I _think_ the door issue was first. Is it possible the door switch is faulty too? And has in some way affected the power supply?
    Any pointers would be appreciated. Thanks.
    #470256
    subspace
    with the door latch check the hinge bearings are not broken or missing
    https://www.bosch-home.co.uk/store/00165296
    jb72
    [USER=”57385″]subspace[/USER] it does sound the same. We’re away now .. I’ll pull the board out when we get back and have a look. [USER=”4209″]electrofix[/USER] do you know if the PCB in ours is similar?
    As for the hinge bearings … I’ve no idea what to check there. Does that bit of plastic deteriorate and lower the door slightly? If I push the door in slightly or apply a bit of pressure to the top of the machine the cycle continues.
    ​​​​​​​Thanks both of you for your responses.
    #470259
    they are right at the bottom of the door its where the hinge pivots. if they break the door lowers by 2mm or so and can cause problems
    your main pcb is at the back rhs
    jb72
    Ah .. that makes sense, a 2mm drop in the door could do that. Thanks.
    Sorry .. is the PCB in the door or at the rear of the machine? … I’m new to this! Is is reasonably easy to get to?
    Thanks again.
    #470261
    subspace
    Pretty sure it’s the same board.
    If its the same layout as mine the board is near the bottom right rear corner. You can get to it by removing the side panel. The position of the power socket will tell you where it is.
    I also replaced the capacitor circled in red as it was supposed to be 470uF but when I tested it, it had fallen to around 330uF.
    [IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”height”:”460″,”width”:”895″,”src”:”https://i.ibb.co/y8TLJ7z/board.png”}[/IMG2]
    #470262
    jb72
    I see .. is that the power socket on the right of the board?
    #470263
    jb72 wrote:I see .. is that the power socket on the right of the board?
    correct
    jb72
    Just to update this.
    Finally got round to replacing the IC as suggested. And despite my particularly ham fisted attempt at soldering it worked .. so far I’ve run 3 successful cycles and it’s not missed a beat. So big thanks for the advice!
    I think if it needed doing again I’d find someone else to do the soldering .. I’m happy doing basic soldering but removing the IC was tricky and I was lucky not to cause major damage to the board!
    I’ll add .. the door bearings looked ok and the machine doesn’t pause as it did, so maybe the problems were linked. We’ll see.
