bosch sms40c02gb/04 dishwasher catch
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch sms40c02gb/04 dishwasher catch
  • #95759
    mikehha
    do bosch have a door latch kit or mod that stops the catch remaining in the closed position when the door is open
    #461279
    why whats the problem you are having
    the catch on this does not have an open or closed position.
    mikehha
    when you open the door the catch stays in the closed position so you can`t shut the door the next time I have changed the latch but it still seems to do it.at first I thought that the top rail was bending allowing the catch to jump over the hole in the door.
    #461281
    have you checked the hinge bearings ? part no 00170830
    mikehha
    Hinge bearings good no play in the door
    #461283
    only really looked how these catches work today did not know they had an open and closed position
    it takes a fair amount of force on the lock finger to reset it in the open position. the only things I can see that would affect it are
    1 damage to the stainless door where the lock engages allowing the finger to slip over the steel
    2 door too low or top bowed up
    have taken a pic of one I have here with a tape measure in so you can see if yours is the same
    dave
    #461284
    mikehha
    I have got an integrated one now doing the same thing remaining in the closed position with the door open.
    #461285
    never had one do this and you have found 2. must be very bad luck
    grooster
    Ive been out to a few that have done this. I just push the catch back in and ive never been back. On one occasion the dishwasher was badly fitted and out of square but I couldn’t see anything wrong with the others.
