Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch sms40c02GB – E25
- This topic has 5 replies, 2 voices, and was last updated 8 years, 1 month ago by
AshSplash.
February 28, 2018 at 5:09 pm #93436
AshSplash
ParticipantHello guys!
I’m hoping you can help with my Bosch Classixx sms40c02GB which is presenting an E25 error mid-cycle.
I understand this to be a drainage issue so I’ve done the following so far:
- Cleared out the drainage pipe and waste pipes behind the machine (nothing crazy, but definitely needed a clean!)[/*:m:7hsqvmnt]
- Inspected the sump from inside the machine, I removed the white impeller cover and ensured there was no grit or glass etc (all clear).[/*:m:7hsqvmnt]
- Dismantled the machine! Removed the drainage pump to feel around for blockages (all clear).[/*:m:7hsqvmnt]
The error still occurs after the above so I’m thinking the pump itself is the issue. I tested the resistance across its terminals with a multimeter and it gave a reading of 117. I couldn’t find any expected results for this model online. The only one I could find was for a “standard dishwasher drainage pump” which was 140-160. I would have thought if it was dead I would have expected it to be lower than 117 though, am I right? It also spins freely (should it?).
The metering / mixing tank on the side also looks like it’s full of spaghetti! But I think that’s unrelated (correct me if I’m wrong).
Many thanks in advance!
February 28, 2018 at 5:40 pm #454308electrofix
ModeratorRe: Bosch sms40c02GB – E25
when the error happens is there still water in the machine ?
also have you checked the plumbing ? a lot of dishwashers connect into a sink and it can be blocked there
February 28, 2018 at 5:47 pm #454309AshSplash
ParticipantRe: Bosch sms40c02GB – E25
Thanks for your reply electrofix, good question, I normally just tell it to try again (it sometimes works on a quick wash). I’ll run it again now and come back to you.
Yep I completely dismantled all the waste pipes behind the dishwasher, all fine.
March 1, 2018 at 1:36 pm #454310AshSplash
I can confirm there is water sat in the bottom of the machine when the error occurs.
March 1, 2018 at 1:48 pm #454311electrofix
well it could be a blockage
and may be the pump. not heard of these pumps failing this way. normally you go to start a programme and it aborts without filling
try operating the unit with the hose into a bucket or over the sink.
is the waist hose down a Stanchion pipe if so make sure it is only inserted the first 8 inches or so. if the pipe ends up in standing water it can cause problems
March 16, 2018 at 9:14 am #454312AshSplash
To close this topic off, the dishwasher has been working faultlessly since the first of March.
electrofix, it is in a Stanchion and I believe it was sat all the way down. I’ve used some string to hold it much higher and everything seems good!
I was too quick to jump to the pump I think.
Thank you!
