I PUT THE MACHINE ON QUICK WASH AND IT FAILED TO COMPLETE BRINGING UP ERROR CODE E 01.
INSIDE I FOUND WATER LEFT IN BOTTOM SO CHECKED PUMP AND FREE.
TRIED TEST CYCLE AND THE CODE E 01 COMES UP IMMEDIATELY.
ON CHECKING THE CODES IT SAYS IT IS A POWER BOARD FAILURE, HOW CAN I CONFIRM.
IF TRUE CAN I GET A REPLACEMEMT AND WILL IT NEED PROGRAMMING BY AN ENGINEER.
FINALLY WHERE IS IT LOCATED AND HOW TO GET ACCESS.
Yes the main power board is the subject of the error. It is located after removing the right hand side panel, at the bottom where the mains plug connects. Costly to replace so caution advised. 🙁
