Bosch SMS4472GB/14
  • #57235
    robbra
    Hi ,
    Had this machine before. Intermittently stops before last rinse. It fills then but not sure if it is reaching the level but I suspect the m/switch. I adjusted the lever and it worked for a while but playing up again. All the hoses are clear and good water pressure.
    #330332
    Re: Bosch SMS4472GB/14
    Sticking float microswitches (027380) are common failings on those older m/c’s. Don’t forget to ensure the black rubber sump hose isn’t clogged also as that could effect the water block device on the inlet/safety valve.:wink:
    #330333
    robbra
    And that would affect the fill but it only happens on the last rinse. Have ordered the complete unit at around £30 as it comes as a complete unit.
    Thanks Martin
    #330334
    Nah don’t bother with the complete Float Assy as it’s only 2 bits of plastic moulding that never fail anyway. Just stick in a new s/w at just £5.46 from BSH and be done.! 😀
    #330335
    robbra
    It’s complete from BSH at about £15 but it doesn’t list the m/sw on its own under that model. Anyway customer is happy at the extra and I’ll be assured it will work ok 😛
    Thanks again Martin.
    Did you see my bit on the impeller jug?
    #330336
    robbra wrote:Did you see my bit on the impeller jug?
    Ever on the ball Rob you know me well by now matey………….. 8)
    #330337
    robbra
    After all these years, oh yes 😛
