Bosch sms50e02gb/04 E15
Viewing 1 post (of 1 total)
  • #94223
    Steven
    Went to this one today related e15 fault – yes there was a small amount of water in base (yellow colour something resembling bile)
    Cleared up and ran a 45deg quick cycle – filled heated up and emptied ok no leak in base.
    I checked the vent on the side and the salt cap and sump so pretty sure it’s not from these areas.
    I also noticed that the side chamber is not pre filling – ready for the rinse!
    The time also when it got to 3 mins left and was draining off jumped straight to 0!
    Did the Same on pre rinse.
    I am assuming this model the side chamber should have prefilled for the rinse and at the end after the regen cycle. Even on the quick wash? this appears not to be happening.!
    What could be the cause? Is this timed so PCB fault or have I missed something?
    If this is not pre filling I’m assuming on the longer cycle the additional water is overfilling from softener unit?
    Steven
