Re: bosch sms50e02gb/04 not filling
pmb wrote:Hi martin thanks for getting back to me just the dropping to one minute, do you need to access fault codes on these?
There is no facility to access error codes on these as far as I’m aware anyway. So in this case if the check water LED and 1 minute shows that could well be E:01 in which case could well mean that the power module is at fault?
The location of those stupid PCB’s makes them vulnerable to dampness ingress so if you think that may be an issue here try removing and drying out the PCB with (for example) a hair dryer. Beyond that I have no clue sorry. 😕
