R/h panel off, Door skin off, plinth off. Cut off hose clip type thingy. Pull out heat pump 😀 Easy peasy. 40mins on a go slow, 15min when you have done a few 😉
Sorry not posted back yesterday as still trying to catch up. Anyway tried removing rh side and module to cut the clip but could not get enough grip or room to cut the clip 😥
So on to the way I done it
Remove both side panels
Straighten tags at either side of tank at rear where is sits in base
Remove screw either side 1/3 way up tank at front attaching tank to hinge.
Remove 2 screws holding fill chamber and unclip. Will sit there on its own.
On the inside remove 4 screws holding sump, cap for air vent and fill cap/housing(large allan key) plus cap/nut for salt container.
With the door open and baskets removed tank will now tilt forward.
Hope I have remembered everything but did not remove plinth/door or disconnect door hinge springs. Just be careful of lower door seal
