BOSCH SMS50E06GB ERROR E02
  • #76661
    johnmac11
    Hi All,
    Got an insurance job to do on one of these tomorrow which has a E02 fault code. Looking at the UKW fault code guide it says that it is a power module fault.
    Will it be the power module or is there anything obvious that would cause this fault?
    thanks
    JM11
    #399383
    Re: BOSCH SMS50E06GB ERROR E02
    It’s the heater relay on the control module that gives this error as a rule John. A new PCB or solder in a new relay should cure. Though be sure and check the heater on the pump as well.:wink:
    #399384
    johnmac11
    Thanks Martin, will do..
    John
