Bosch SMS53E12GB Error code E01
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SMS53E12GB Error code E01
  • #96761
    Tony Whitley
    (Spare parts searches have SMS53E12GB/some number but the label on the back just says SMS53E12GB. The control unit is EPG60110 dated 10.03.2010, the wiring to it looks OK and I reseated the connectors but it made no difference)
    Searches suggest the heater or the control unit. The dishwasher stops about an hour into the cycle and the dishes are dry but not properly clean. There has been hot water in it (it’s slightly steamy but perhaps not as steamy as I’d expect).
    Judging by the control unit date the dishwasher is 9 years old so replacing the £100+ controller doesn’t seem worth while but I read here something about fixing another dishwasher that had a dry joint on the PCB.
    What is your advice?
    Thanks.
    #464728
    Tony Whitley
    (It seems you have new forum software which unfortunately doesn’t accept error codes as search terms because they’re too short.)
    #464729
    Tony Whitley
    Thanks, looks like I’ll be buying a new dishwasher then, I was kind of expecting that.
    #464731
    Tony Whitley wrote:(Spare parts searches have SMS53E12GB/some number but the label on the back just says SMS53E12GB. The control unit is EPG60110 dated 10.03.2010, the wiring to it looks OK and I reseated the connectors but it made no difference)
    Thanks.
    it was a common fault on Bosch dishwashers for the heater relay solder joint to fail
    if your looking for the model its normally on top of the door on the silver part on an almost invisible label
    Tony Whitley
    Thanks Dave, I’ll give that a try and report back.
    #464733
    Tony Whitley
    OK, no sign of any overheating joints and I didn’t know which of the 5 relays was for the heater so I went round them all and reflowed the joints. It certainly had an effect – now I get an E28 error (drain error) after a minute 🙁 Oh well, it was worth a try.
    #464734
    on later machine they measure the pump current to determine when its empty. a very worn pump can take more current and fool it but it could just be the board
    on earlier machine they use an air operated pressure switch
