bosch sms53e22gb/55
  • #87003
    eng14
    this d/w had blocked sump with broken glass,pumps out now but will not fill,richard. 🙁
    #433645
    Re: bosch sms53e22gb/55
    Silly question but, have you ‘reset’ the programme?
    #433646
    eng14
    yes tried that.
    #433647
    nomadPaul
    Have you replaced the drain pump cover correctly? This machine carries out tests on drain pump , heat pump and water pressure prior to filling. If its not reaching the filing stage stage , I’d suggest a continuing problem with the drain pump or even a piece of glass stuck in the heat pump.
    #433648
    eng14
    looks like glass in wash/heat pump
