Bosch sms63e09gb/07 heat pump replacment 09 fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch sms63e09gb/07 heat pump replacment 09 fault
  • #76998
    Johnnyboy
    Is there an easy way to do this one it looks a mare.
    #400364
    timdowning
    Re: Bosch sms63e09gb/07 heat pump replacment 09 fault
    Easier than the previous range. I did one the other week by just taking lid,side panel off and removing module. You can then reach into motor/heat pump to remove. make sure theres a new hose clamp in the box.
    #400365
    Johnnyboy
    seemed too easy, will wait till monday when the office get a call for it flooding. Cheers Johnnyboy
    #400366
    Simon46
    Is it a bayonet fit or just pulls out after removing straps?
    S.
    #400367
    lee8
    Once the rubber mount and hose clip is removed it simply pulls out. Not had many leaking the trick to the hose clamp is to tighten it enough before placing on hose that allows it to slid into position and not move when you tighten with a screw driver, otherwise trying to position your hand to hold it and have enough room to place other hand with screw driver and see screw head is difficult.
    #400368
    Simon46
    Cheers Lee. wash Pump sounds terrible when it starts up then it jams. Then e21 appears.
    #400369
    lee8
    Possibly has something inside it should not have.
    #400370
    Simon46
    Asked her about glass she thinks one broke a couple of months ago. So will post after visit on weds.
    S.
    #400371
    Simon46
    just to clarify impeller has sheared off shaft. Replacement pump has totally different wiring loom included with pump after I found the first replacement pump had different plugs. Pump fitting was easy then just the conversion/splicing of wiring to new plugs. Mine was a GB/05 so BSH it for diagrams/correct pump first.
    S.
