bosch sms63e12gb/01 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch sms63e12gb/01 dishwasher
  • #80055
    suedehead1
    hi,
    got an E24 fault seems to pump ok no blockages, removed the
    non return valve but it runs for about 5 mins then E24.
    any advice welcomed.
    #411503
    Re: bosch sms63e12gb/01 dishwasher
    thought it was one of the later ones but had to check
    the way bosch detects if the unit is empty is to monitor the pump current. so the pump draws less current when empty. as the pump wears it starts to bind and gives the timer false signals
    first thing i would do is replace the pump part no 00611332 and see if things go ok from there
    suedehead1
    Ok thanks I will give it a try.
    #411505
    Andy jones
    Reed switch.
    #411506
    nomadPaul
    To be honest , intermittent e:24 is such a pain in the backside. Whilst it can mainly point towards slow draining , it can be a blocked drain hose/sink connection, stuck non-return valve , drain pump access cover loose , faulty/blocked drain pump or failing/blocked heat pump . It can sometimes be difficult to diagnose especially when it doesn’t occur when you’re there. Sorry I can’t be more specific but the error code has too many possibilities to pinpoint it exactly without examining or testing the machine personally.
    #411507
    suedehead1
    totally agree I have seen some posts where a new pump hasnt cured it.
    It seems strange that it runs for 4 or 5 minutes before E24 comes up.
    detecting pump current seems an unusual way of doing things.
    #411508
    suedehead1
    changed pump and reed switch but its still shows E24, I give up.
    #411509
    nomadPaul
    Drain pump or heat pump ?
    #411510
    timdowning
    I had a customer ring who had been managing an e24 on this machine for a while. She managed the fault by opening & closing the door when e24 appeared. (This was after a few minutes, whether she pushed start again I don’t know), I gave a few prices and never heard anymore from her.
    #411511
    suedehead1
    It was the drain pump i changed i will be avoiding this fault if I see it again.
