Re: Bosch SMS6702
Hi zania
Check you have no kinks (bends) in water hoses to machine inlet valves..
If these check out ok, your next step is to switch off machine at power outlet, and remove plug if possible..
Then after turning off water supply at taps, you slowly remove water pipes from rear of machine..
Then look at the small white plastic filter, which is simply slid in to the rear of the inlet valve on machine.. If these need cleaning they can be pulled out using a long nose pliers or similar tool..
If after these steps you still have the problem.. Then its more than likely the water inlet valves need replacing..
Hope this helps
