Bosch SMS69L12GB
  • #77233
    timdowning
    Customers rang with an intermittent E23 fault.
    With a bit of resetting they can normally get the machine to start, eventually.
    Apparently the man of the house has changed the flow sensor but to no avail.
    The fault happens within a minute or two of starting, once they have reset it a few times it goes through the cycle ok.
    Is E23 a pump fault on these?
    Ta.
    #401511
    nomadPaul
    Re: Bosch SMS69L12GB
    E:23 is incorrect resistance values of drain pump. E:24 and E:25 are actual draining faults.
