Re: Bosch sms9022GB/014
Drain pump controlled by float switch in the base so maybe that’s jammed with something underneath it maybe?
Aquastop valve may be at fault here but first you need to check the flow from the stopcock first? If the pressure is good then the valve filter is either crudded up or the aquastop valve faulty? Also check that the float in the matrix isn’t sticking and that the black sump hose from the matrix isn’t crudded up either?
Finally, in hard water areas, and where folks don’t use salt in their machine mostly, the inlet nozzle at the top of the matrix can getting scaled up and cause water not to flow correctly down the matrix and mostly through the overflow into the tub instead (one to look out for. :wink:)
HTH?
Let us know how you get on.:D
