Bosch SMV40C30GB/46 Dishwasher Wiring Diagram
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMV40C30GB/46 Dishwasher Wiring Diagram
  • #98459
    jontymox
    Good afternoon everyone,
    Would anybody be able to send me a wiring diagram for the above Bosch dishwasher?
    Thank you,
    jonty
    #472429
    not many of us have bosch tech access but may be able to help if you have a fault
    jontymox
    Good evening Dave,
    The problem is I replaced the heat pump about four weeks ago, due to a no heat fault.
    However, the fault has recurred, and I suspect the power module/board.
    I feel the heat pump, board, and associated wiring is very difficult to test conclusively, due to some of the tiny connections etc, and would like a wiring diagram to try and see what all these connections relate to.
    The replacement heat pump is a genuine Copreci part, and wiring continuity from board to heat pump all fine.
    #472431
    so has it blown it again or is it just not heating ?
    jontymox
    Hello Dave,
    I suspect the board, as the wiring continuity from board to heat pump is fine.
    There is technical information/bulletin regarding testing Bosch group heat pumps electrically, but I don’t have the details for this type….
    #472433
    so have you checked if the heater has blown as you can do that with a multimeter in the large terms
    jontymox
    Yes, replacement heat pump remains fine.
    I still suspect the board, but would like a wiring diagram….
