Bosch SMV40C40GB/45 D/W Not Drawing Water & Tap Light On
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMV40C40GB/45 D/W Not Drawing Water & Tap Light On
  • #101846
    jontymox
    Good afternoon all,
    I realise the above fault can relate to several possible causes, and wonder if there is a diagnostic mode I can access, and if the aquastop hose is electrically testable?
    The machine drains normally when a new cycle is selected, then pauses, with no attempt to draw water, prior to the unit aborting the cycle shortly afterwards.
    (hence, it can’t be a flow sensor/jug or matrix fault.)
    The tap light also lights, along with an audible beep… but I can’t remember if the tap light flashes, or remains lit, following my visit this morning! (I gather the “status” of the tap led is crucial when diagnosing such a fault.)
    Thanks in advance for any help!
    jonty
    #486427
    if its solid its a water problem valve , tap kinked hose etc
    if its flashing it can be anything else
    jontymox
    Thanks Dave,
    I suspect the fault lies either in the aqua-stop hose or board, and will return to do more tests.
    Does anyone know how to conclusively test the aqua-stop, as it is sealed?
    jonty
    #486429
    jontymox
    agua-stop fill valve sealed/potted.
    #486430
    its still only a valve
    so you can measure the coil and check to see if its powered up or not
    jontymox
    Thanks again,
    I thought the unit was completely sealed, and didn’t want to break anything…
    Will return, and update.
    #486432
    Hollytree_Technical
    Easiest place to test the valve electrically is to go the back of the machine and pop out the panel where the hoses enter the machine, there is a connector on the back of the panel for the valve. You should get the usual 3.5K to 4.5K resistance reading, also if the resistance is good you can put a current clamp round one of the wires to see if it gets powered at all.
    Jem
    #486433
    jontymox
    Thanks for that info’ Jem,
    Will update early next week, as too busy to return until then…
    jonty
    #486434
    jontymox
    Good evening,
    Established fill valve/aqua stop fine (good ohms reading) but no supply from board.
    Wiring to/from above fine, yet new and programmed board costs nearly £200.00!
    jonty
    #486435
    may also be a pump as they use the current to the pump as a virtual sensor. if the pump is worn it will draw more current and fool the board into thinking its not drained
