Bosch SMV4HVX38G/45 finishes program after 30 seconds
Home Forums General Trade Forum Bosch SMV4HVX38G/45 finishes program after 30 seconds
  • #103076
    ali_g12
    This 2023 Bosch SMV4HVX38G/45 dishwasher can start a program but doesn’t get beyond the drain pump phase. The board relay clicks but no action from the pump and then timer goes down to 0:00 and machine beeps to signify finish. No error codes.
    I was able to get the pump to run on one occasion by manually turning it but then the same process didn’t work after that.
    I will go back and replace both drain pump and heat pump to see whether that gets any result.
    Any thoughts? I haven seen this one before.
    #491705
    stratfordgirl
    I’ve not come across that exact behaviour, but from occasional experience of abnormal pump behaviour at the start of the cycle on this dishwasher platform, I too would suspect a pump fault. A bug in the on-board diagnostic software may explain the lack of a fault code, or alternatively suggest a hardware failure on the pcb.
    I assume you are aware that the machine is still under the manufacturer’s 2-year guarantee.
    #491706
    ali_g12
    Thanks for the input, will endeavour to update the thread once I’ve replaced the pump.
    As for the warranty, it’s in a commercial environment!
    #491707
    kaibart
    Heat pump or power module will be faulty more likely heat pump
    #491708
    ali_g12
    kaibart wrote:Heat pump or power module will be faulty more likely hest pump
    Thanks. I’ll let you know.
    #491709
    ali_g12
    Replaced heat pump and module…………no dice. Must be module.
    #491710
    ali_g12
    ali_g12 wrote:Replaced heat pump and module…………no dice. Must be module.
    Sorry that should read ‘replaced drain pump and heatpump’
