Bosch SMV50C00gb/03 not starting
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMV50C00gb/03 not starting
  • #77729
    simtoms
    Hi Folks,
    I called to this integrated model yesterday and the display seems to function ok but won’t start a wash. At one stage it ran the drain pump so I know that’s working, but when all went back together it’s the same initial fault. When you first turn on there’s a few grumbly noises, but once you hit start and the light goes solid there’s no internal responses. No error signals. Sound familiar to anyone?! Thanks, Simon
    #403213
    Re: Bosch SMV50C00gb/03 not starting
    Those “grumbly noises” I take it is the drain pump running? That being the case then after the pump runs for a few seconds it should then start filling. So I’d take a look at the fill valve, flow meter to see what gives there. 💡
    #403214
    simtoms
    Thanks Martin,
    No, there’s no noises at all once you’ve pressed start. The only noises are when you press the on/off button, and it isn’t the sound of the pump running. Simon
    #403215
    A close look at the Power module is called for I reckon and that daft designed kettle plug connection.
