I had a call to the above machine as the door drops.
I have replaced the Hinge/spring repair kit.
Problem is the door opens below the horizontal position.
The inner door panel is slightly buckled on one side. It’s very difficult to tell if the hinges or brackets that restrict the opening are damaged.
When this happens do the hinges and brackets normally need replacing as well or is it normally just the inner door?
