Bosch smv50c10gb float issue?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch smv50c10gb float issue?
  • #96661
    Wayne_richards
    I have a Bosch smv50c10gb that is stopping after the first rinse (appears to be when it is draining) restarting it normally gets it to work. It has the tap light on when it stops.
    From the research i have done i think it is an issue with the level float getting stuck but i can’t locate it.
    #464367
    the only float in that machine is the overflow sensor in the base. if that was triggered it could not be restarted
    if its a drain fault check for blockages
    Wayne_richards
    Thanks Dave, so I have thoroughly checked for blockages(pump, pipe from pump, labyrinth,drain hose and drain it drains into)
    So a few things have progressed, I have been watching the side of the machine pulled whilst it is pulled out into the room and I can see it draining and filling fine but I have seen what it is doing when it stops.
    So it has got worse, current symptoms are it stops randomly (before wash, after pre rinse, later before rinse?) And beeps with the tap light on. When it does finish it also has the tap light on.
    So I am stumped.
    Wayne
    #464369
    well its very probably
    https://shop.ukwhitegoods.co.uk/611317-bosch-dishwasher-flow-meter
    in the left side fill module is the small pcb. its job is to count the water in. if it fail then the tap light comes on and the machine will think its overfilling and pump out the water. ignore the plastic frame its only for packaging
    you would need to check this is the correct one for your machine as you have not included the last 2 digits of the Enr number
    Wayne_richards
    Thanks for the prompt reply, I can’t find the one for my model.
    smv50c10gb/01
    #464371
    correct one above
    https://www.bosch-home.co.uk/customer-service/care-protection-and-parts/spare-parts
    item 0405 page 4
    part no 611317
    or you could find a similar reed switch and solder it on. I do that all the time
