bosch smv50e00gb/01
  • #102108
    Tom
    Bosch dishwasher SMV50E00/GB01
    Hoping someone can help. Looking at the contro board for this dishwasher. Two versions; programmed and unprogrammed are available. Does the un programmed come with programming instructions or do Bosch engineers have to do programming. Quite a difference in price.
    tom
    #487611
    any unprogrammed board would need access to a programmer and the revlavent software
    kaibart
    Just you can only use programmed module as it need programming with bosch equipment part number you need is 00647251
    #487613
    kaibart wrote:Just you can only use programmed module as it need programming with bosch equipment part number you need is 00647251
    and if you get this where does the correct software come from ?
    kaibart
    No that’s the part number for programmed module you need the bosch dcu for programming which only bosch engineers have.
    Kai
