Bosch SMV50EOOGB/21 stopping in cycle.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SMV50EOOGB/21 stopping in cycle.
  • #79870
    aqualectric
    Bosch SMV50EOOGB/21 intergated dishwasher. FD9010.
    Drains, fills, washes, heats, drains out……water level OK… no water in base tray….. outlet to stand pipe so no siphoning…. 😐
    Taking 3 – 4 hours to wash. Stops with wash ‘brush’ light on but nothing happening. Crocks are clean but machine doesn’t finish although it has drained out.
    Apart from a module fault am I missing something?
    Thanks!
    Steve.
    #410886
    Re: Bosch SMV50EOOGB/21 stopping in cycle.
    It could just be a faulty Turbidity sensor. 💡
    #410887
    aqualectric
    Can’t find a turbidity sensor on that model, Martin…..
    #410888
    aqualectric wrote:Can’t find a turbidity sensor on that model, Martin…..
    Yeah sorry, just looked it up and it doesn’t have one. 🙁
    #410889
    OK just looked up error codes on this one. Brush LED flashing = E14 Flow sensor detects no impulse even though circl pump detects water. In plain English the reed switch needs changing. 😀
    #410890
    nomadPaul
    It could be just a dodgy install or lock . Brush led flashing on its own normally means the programme has been interrupted. I’d be looking at a new lock AND , if its got the plastic frame that it sits in , the additional fixing plate that is fitted on top of the lock to hold it in position. Unfortunately I don’t have immediatel access to the part number at the moment.
    #410891
    nomadPaul
    Ok , having now looked at the model , it appears to be a full metal tub appliance. I’d ask the customer to press on the door when it ‘stops’ to see if it restarts ? If it does then weak lock or installation problem to blame I think.
    #410892
    aqualectric
    Customer finally got back – and it seems that when he pushes the door it restarts….. 😯
    So is the sensor in the door the faulty part or the latch unit on top of the machine?
    Thanks for the help so far, guys; much appreciated!!
    Cheers,
    Steve.
    #410893
    nomadPaul
    1st thing – check installation to make sure the decor door/door seal/fixing brackets aren’t preventing the door from closing properly. You should also check that there isn’t anything behind the appliance – plug socket/pipes/cables etc – pushing on the rear wall. This can push the top basket fwd , putting pressure on the door and causing sensor/magnet misalignment. One way to check is to bring the machine forward and run a cycle with the machine out of its install . If all that is ok , I’d be looking at a new door lock. Have only ever changed one sensor but that brings up an error code.
